Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
Formula Editor
Customize Formulas
• Change the Orientation of a Formula
JMP.com/help
By default, JMP determines the size of a formula and displays it in the Formula Editor in the best orientation (horizontally or vertically). However, if you create a long formula, you might want to display it in a different layout.
To change a formula’s orientation, follow these steps:
Build a formula.
Highlight an argument or formula.
Right-click what you have highlighted.
Select
Orientation
Select from the Orientation options: Best, Horizontal, or Vertical.
Help created on 3/19/2020
