Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Scripting Guide
Scripting Tools
Using the Script Editor
• Color Coding
JMP.com/help
Color Coding
On Windows, the default font in the script editor is 10-point Consolas. On Macintosh, the default script editor font is 13-point Menlo.
JMP applies the following colors in the script window:
black for text, identifiers (JSL functions), braces, and user macros
white for the script editor background
gray for the disabled background and guides
green for comments
purple for strings
maroon for platform names
Note:
If a platform name is used in a message, the JSL messages color is used.
teal blue for numbers
dark blue for operator symbols, the first keyword, and JSL messages
medium blue for function names, second and third keywords, and macros
red for unknown objects
You can customize colors and fonts in the Customize Styles section of the Script Editor preferences. Syntax coloring for JSL, the log, SAS code, JavaScript, Text, JMP Text Analytics, R, Matlab, Python, C, JSON, and SQL are supported.
Help created on 3/19/2020
