Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
The Fit Definitive Screening Platform
Fit Definitive Screening Report
• Combined Model Parameter Estimates
JMP.com/help
The Combined Model Parameter Estimates report lists the terms in the final model and their usual standard least squares estimates, standard errors, t ratios,
p
-values, RMSE, and model degrees of freedom.
Below the report are buttons that construct or run the combined model.
Figure 8.10
Combined Model Parameter Estimates Report
Make Model
Creates a model for the Fit Model window containing the model terms in the Combined Model Parameter Estimates report and the response specified for the Fit Definitive Screening analysis. The Standard Least Squares personality is specified.
Run Model
Runs a standard least squares fit for the model terms in the Combined Model Parameter Estimates report and the response specified for the Fit Definitive Screening analysis.
Help created on 3/19/2020
