Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Compare Designs
• Compare Designs Window: Specify Model and Alias Terms
JMP.com/help
The Compare Designs window consists of two sets of outlines:
Specify which effects are in the model and which effects are potentially active using the Factors, Model, and Alias Terms outlines.
Compare the designs using the diagnostics in the Design Evaluation outlines. Changes that you make in the Model and Alias Terms outlines are updated in the Design Evaluation report.
The Compare Designs report uses the column names from the reference design.
This section describes the Reference Design, Factors, Model, and Alias Terms outlines. See
Compare Designs Window: Design Evaluation
for a description of the Design Evaluation outlines.
Help created on 3/19/2020
