Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Partial Least Squares Models
Statistical Details for the Partial Least Squares Platform
• Confidence Ellipses for X Score Scatterplot Matrix
JMP.com/help
The Score Scatterplot Matrices option adds 95% confidence ellipses to the X Score scatterplots. The X scores are uncorrelated because both the NIPALS and SIMPLE algorithms produce orthogonal score vectors. The ellipses assume that each pair of X scores follows a bivariate normal distribution with zero correlation.
Consider a scatterplot for score
i
on the vertical axis and score
j
on the horizontal axis
The coordinates of the top, bottom, left, and right extremes of the ellipse are as follows:
the top and bottom extremes are +/-sqrt(var(score
i
)*z)
the left and right extremes are +/-sqrt(var(score
j
)*z)
where
z
n
-1)*(
n
-1)/
n
)*BetaQuantile(0.95, 1, (
n
-3)/2). For background on the z value, see Tracy et al. (
1992
Help created on 3/19/2020
