Each component in a Reliability Block Diagram can be assigned a failure distribution. The available failure distributions are listed in Table 11.2. To see the formulas and parameterization for these failure distributions, see Distributions in Life Distribution.
For Knot components, enter the Minimum Available Dependences. The Knot shape enables you to configure a k-out-of-n shape where the shapes that are joined have different distributions. The Minimum Number of Dependencies is k, the minimum number of paths leading to the Knot that need to function in order for the system to function.
