LCL for XBar chart =
UCL for XBar chart =
LCL for R-chart =
UCL for R-chart =
Center line for R-chart: By default, the center line for the ith subgroup (where 3 is the sigma multiplier) indicates an estimate of the expected value of Ri. This value is computed as: , where is an estimate of σ.
The standard deviation for XBar and R-charts is estimated by:
= weighted average of subgroup means
σ = process standard deviation
ni = sample size of ith subgroup
d2(n) is the expected value of the range of n independent normally distributed variables with unit standard deviation
d3(n) is the standard deviation of the range of n independent observations from a normal population with unit standard deviation
Ri is the range of ith subgroup
N is the number of subgroups for which ni ≥ 2.
Help created on 3/19/2020
