Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Basic Analysis
Contingency Analysis
Correspondence Analysis
• Correspondence Analysis Options
JMP.com/help
Use the options in the red triangle menu next to Correspondence Analysis to produce a 3-D scatterplot and add column properties to the data table.
3D Correspondence Analysis
Produces a 3-D scatterplot.
Save Value Ordering
Takes the order of the levels sorted by the first correspondence score coefficient and makes a column property for both the X and Y columns.
Help created on 3/19/2020
