Select Help > Sample Data Library and open Companies.jmp.
Select Rows > Row Selection > Select Where.
Select Size Co in the column list box on the left.
Hold down the Ctrl key and select the Type, Sales ($M), and Profits ($M) columns.
7.
Select Tables > Subset to launch the Subset window.
Figure  .26 Subset Window
8.
Select Selected columns to subset only the columns that you selected. You can also customize your subset table further by selecting additional options.
9.
Select Analyze > Distribution.
Select Type and click Y, Columns.
Caution: This method creates a linked subset table. This means if you make any changes to the data in the subset table, the corresponding value changes in the source table.
Help created on 3/19/2020
