Select DOE > Special Purpose > Space Filling Design.
Alter the factor level values, if necessary. Figure 21.10 shows adding two factors to the two existing factors and changing their values to 1 and 8 instead of the default –1 and 1.
Click Continue.
In the design specification dialog, specify a sample size (Number of Runs). This example uses a sample size of eight.
6.
Click Latin Hypercube (see Figure 21.7). Factor settings and design diagnostics results appear similar to those in Figure 21.11, which shows the Latin Hypercube design with four factors and eight runs.
