Select DOE > Special Purpose > Space Filling Design.
Click Continue.
In the Define Linear Constraints outline, select Specify Linear Constraints.
Select Add.
7.
Type 200 next to Number of Runs.
8.
Select Fast Flexible Filling.
9.
Select Make Table to construct the data table.
With the data table active, select Graph > Graph Builder.
Remove the Smoother by clicking the smoother icon.
In the Graph Builder red triangle menu, click Show Control Panel to deselect it.
You should see a graph similar to the one in Figure 21.24. Note that the points satisfy the linear constraint
