Fits the distributions that were not selected in the launch window. The available distributions are listed under Distribution.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
Figure 5.7 shows the Simulation Configuration Panel. The initial values for Distribution and the parameter settings are determined by the parameter estimates for the distribution specified in the Cumulative Damage launch window. The graph shows the estimated failure distribution functions over time for the stress patterns defined in the Stress Pattern data table.
