Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Bootstrap Forest
The Bootstrap Forest Report
• Cumulative Validation
JMP.com/help
(Available only if validation is used.) Shows a plot of the fit statistics for the Validation set versus the number of trees.
For a continuous response, the single fit statistic is R-Square. For a categorical response, the fit statistics are listed below and are described in
Measures Report
RSquare (Entropy RSquare)
Avg - Log p (Mean - Log p)
RMS Error (RMSE)
Avg Abs Error (Mean Abs Dev)
MR (Misclassification Rate)
The Cumulative Details report below the Cumulative Validation plot gives the values used in the plot.
Help created on 3/19/2020
