Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
CUSUM Control Charts
The CUSUM Control Chart Platform Report
• CUSUM Chart
JMP.com/help
CUSUM Chart
The CUSUM Chart report contains the cumulative sum control chart with decision limits that are determined by the current values of the chart parameters. The samples (or subgroups if an X variable is specified) are denoted on the horizontal axis. The vertical axis contains centered values of the positive and negative values for the cumulative sum. If the Data Units option was not selected in the launch window, the vertical axis represents cumulative sums for standardized response values. If the Data Units option was selected in the launch window, the vertical axis represents cumulative sums for unstandardized response values.
Help created on 3/19/2020
