The factors and their settings are given in the data table Extraction Factors.jmp. You create a definitive screening design to investigate.
Select DOE > Definitive Screening > Definitive Screening Design.
From the red triangle menu, select Load Factors.
Click Continue.
The Design Options outline opens. Here you can specify a blocking structure. There is no need to block in this example, so you accept the default selection of No Blocks Required.
6.
Click Make Design.
7.
Open the Design Evaluation > Color Map on Correlations outline.
8.
