Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Definitive Screening Designs
Definitive Screening Design Window
• Design
JMP.com/help
Design
The Design outline shows the runs for the definitive screening design. The runs are given in a standard order. To change the run order for your design table, you can select Run Order options in the Output Options panel before generating the table.
Note:
Definitive screening designs for four or fewer factors are based on a five-factor design. See
Definitive Screening Designs for Four or Fewer Factors
Help created on 3/19/2020
