The Alias Matrix in Figure 5.5 shows partial aliasing of effects. In other cases, main effects might be fully aliased, or confounded, with two-factor interactions. In both of these cases, strong two-factor interactions can confuse the results of main effects only experiments. To avoid this risk, create a design that resolves all two-factor interactions.
Select DOE > Custom Design.
Type 5 next to Add N Factors.
Click Add Factor > Continuous.
Click Continue.
In the Model outline, select Interactions > 2nd.
6.
Click Minimum to accept 16 for the number of runs.
Note: Setting the Random Seed in step 7 and Number of Starts in step 8 reproduces the exact results shown in this example. In constructing a design on your own, these steps are not necessary.
7.
(Optional) From the Custom Design red triangle menu, select Set Random Seed, type 819994207, and click OK.
8.
9.
Click Make Design.
Figure 5.7 shows the runs of the design. All main effects and two-factor interactions are estimable because their Estimability was designated as Necessary (by default) in the Model outline.
10.
Open the Design Evaluation > Color Map on Correlations outline.
