Discriminant Analysis
Discriminant Analysis Specifications Window
Discriminant Analysis Report
Discriminant Analysis Report Options
Saves formula columns to the data table for the prediction of the most likely response. The first saved column contains a formula that uses the Text Score() function to calculate the probability for each response level. There are also columns that contain probabilities for each response level as well as a column that contains the predicted response.
Help created on 3/19/2020
