Returns the menu items used for popup menu when the button is clicked. For submenus see <<Get Submenu(index). Menu items are returned in a list.
w = New Window( "Window",
Text Box( "Page Setup Test" )
w << Get Page Setup();
{Margins( {0.75, 0.75, 0.75, 0.75} ), Scale( 1 ), Portrait( 1 ),
Paper Size( "Letter" )}
xy = DisplayBox << Get Size;
{ x, y } = DisplayBox << Get Size;
The example below creates a menu containing “A”, “B”, and “C” with “A” having a submenu “A1” and “A2” and “B” having a submenu “B1”, “B2”, and “B3”. <<Get Submenu(inc) returns the number of submenu items under each indexed menu item.
New Window( "Title",
obj = Outline Box( "title" ) );
submenus = { };
obj << Set Menu Script(
{"A", "", "A1", Print( "A1" ), "A2", Print( "A2" ),
"B", "", "B1", Print( "B1" ), "B2", Print( "B2" ), "B3", Print( "B3" ),
"C", Print( "C" )}
obj << Set Submenu( 1, 2 ); // menu A with 2 items in submenu A1 and A2
obj << Set Submenu( 4, 3 ); // menu B with 3 items in submenu B1, B2, and B3
For( inc = 1, inc <= N Items( Words( obj << Get Menu Script, "," ) ), inc++,
Insert Into( submenus, obj << Get Submenu( inc ) );
submenus;
{2, 0, 0, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
New Window( "Example",
Outline Box( "Parent display box",
Button Box( "OK", <<Horizontal Alignment( "Center" ) )
Consider including the message <<Update Window rather than including Wait(0). The problem with using Wait(n) is knowing how large n should be.
Many display box messages, such as <<Set Text, automatically mark the box as invalid, so the <<Inval message is usually unnecessary. Some interactive scripts that use sliders with JSL callbacks may need <<Update Window to keep various parts of the display synchronized with the slider.
biv = dt << Bivariate( y( weight ), x( height ) );
rbiv = (biv << Report);
rbiv << Save Interactive HTML( "$DOCUMENTS/MyInteractiveHTML.htm" );
The PDF file contains headers and footers. Use Save Picture to omit these components.
Pref( Save Image DPI( <number> ) );
Use Save Picture to export a report as a PDF file with no headers or footers. Use Save PDF to include these components.
The quoted location of the saved file. You must include the .pptx extension in the filename. An existing file with the same name is overwritten.
Optional. The quoted path name and file name of a custom PowerPoint template. Without this argument, JMP uses the default template located in the pptx folder of the installation directory.
Include a simple table in your template, or a default table format is applied to report tables. For an example on Windows, see /pptx/JMPExportTemplate.pptx in the JMP installation folder.
n inserts the slides as the nth slide number.
"Begin" inserts the slides at the beginning of the presentation.
"End" inserts the slides at the end of the presentation.
Optional. Determines which slides are replaced in an existing presentation. The arguments are n, "Begin", and "End" as described for Insert.
"None" omits the slide title above the graphic and the outline titles.
"Hide" omits the outline titles.
"TopLeft", "TopRight", "BottomLeft", "BottomRight" determine the position of any of the parent outline titles on the slide.
Optional. The quoted format of the embedded graphics. Options are "Native", "EMF", "PNG", "JPG", "BMP", "GIF", "TIF". On Windows, the native format is EMF. On Macintosh, the native format is PDF. See “Notes” for compatibility issues. Without this argument, JMP applies the “Image Format for PowerPoint” General preference.
Windows does not support the native PDF graphics produced on Macintosh. Macintosh does not support the native EMF graphics produced on Windows. For cross-platform compatibility, specify "PNG", "JPG", "GIF", or "TIF".
Sets the page settings. Margins are set in inches. Scale variable s is a number in the range of 10 (for 1000%) to 0.2 (for 20%) with the default as 1 (for 100%). If portrait is True the page is oriented for portrait, otherwise the page is landscape. Paper size is a string specifying the paper size, for example, "Letter" or "Legal".
w << Set page setup(
margins( 1, 1, 1, 1 ),
scale( 1 ),
portrait( 1 ),
paper size( "Letter" )
w = New Window( "Window", Text Box( "Header Example" ) );
w << Set Print Headers(
"Today is: &d;" // left,
"&wt;" // center,
"Page &pn; of &pc;" // right
w << Print Window;
w = New Window( "Window", Text Box( "Footer Example" ) );
w << Set Print Footers(
"&wt;" // center,
w << Print Window;
New Window( "title", ob = Outline Box( "title" ) );
ob << Set Menu Script(
"C", Print( "C" )}
ob << Set Submenu(1, 2); // menu A with 2 items in submenu A1 and A2
ob << Set Submenu(4, 3); // menu B with 3 items in submenu B1, B2, and B3
