Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Standard Least Squares Report and Options
Statistical Details for the Standard Least Squares Personality
• Emphasis Rules
JMP.com/help
Emphasis Rules
The default emphasis in the Fit Model launch window is based on the number of rows,
n
, the number of effects (
k
) entered in the Construct Model Effects list, and the attributes applied to effects.
If
, the Emphasis is set to Minimal Report.
If
and
, the Emphasis is set at Effect Leverage
If
and
, the Emphasis is set at Effect Screening.
If
and
and
, the Emphasis is set at Effect Leverage.
If any effect has a Random Effect attribute, the Emphasis is set to Minimal Report.
If none of these conditions hold, the Emphasis is set at Effect Screening.
Help created on 3/19/2020
