The following example uses the Big Class.jmp sample data table, which contains data on age, sex, height, and weight for 40 students. Examine the relationships between different variables.
Select Graph > Parallel Plot.
Select the Scale Uniformly check box.
7.
Click OK.
From Figure 9.12, you observe the following:
