This example uses the Dogs.jmp sample data table, which contains histamine level measurements for 16 dogs that were given two different drugs. The histamine levels were taken at zero, one, three, and five minutes. Examine the variation in the histamine levels for each drug.
Select Rows > Color or Mark by Column.
Select drug.
If the selection shown in your Colors menu is JMP Default, morphine is assigned the color red and trimeth is assigned the color blue.
Click OK.
Select Graph > Parallel Plot.
6.
7.
Click OK.
8.
Select Rows > Data Filter.
9.
10.
From Figure 9.3, you observe the following about the histamine levels for dogs given trimeth:
