Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Accelerated Life Test Designs
• Example of an Accelerated Life Test Design
JMP.com/help
In this example, suppose that you need to design an accelerated life test for a mechanical component. The single acceleration factor is torque, and the normal use stress is 35 Nm (newton meters). You want to estimate the time at which 10% of the units fail at the normal use stress. You construct a failure probability optimal ALT test.
Your test plan has the following characteristics:
A total of 100 units are available for testing.
The life distribution is assumed to be Weibull.
The life-stress relationship is given by the logarithmic transformation.
You plan to test torque at three stress levels: 50, 75, and 100 Nm.
You have prior knowledge to predict initial failure times at the test levels. See
Obtain Prior Estimates
The test will continue for 5,000 cycles.
You will monitor the process for failures on a continuous basis.
Help created on 3/19/2020
