This example uses the Big Class.jmp sample data table. Examine if the difference in height between males and females is less than 6 inches.
Select Help > Sample Data Library and open Big Class.jmp.
Select Analyze > Fit Y by X.
Select height and click Y, Response.
Select sex and click X, Factor.
Figure 6.30 Example of an Equivalence Test
Help created on 3/19/2020
