Select DOE > Special Purpose > Balanced Incomplete Block Design.
Select 2 for the Block Size.
Select 3 for Allowable Blocks.
Note: You can enter a Treatment Name, Block Name, and Treatment Labels to customize your design table.
Click Make Design.
The design has six runs in three blocks with two treatments in each block as seen in the Block Design outline. For additional design details open the Design and Incidence Matrix outlines. See Verify Design and Make Table.
6.
Select 6 in the Allowable Blocks menu.
7.
Click Make Design to update the design.
8.
Open the Incidence Matrix outline.
