Select Analyze > Fit Y by X.
Click OK.
6.
Select Fit Line from the red triangle menu.
7.
From the Linear Fit menu, select Remove Fit.
8.
From the red triangle menu, select Group By.
9.
10.
Click OK.
11.
The scatterplot to the left in Figure 5.24 has a single regression line that relates weight to height. The scatterplot to the right shows separate regression lines for males and females.
