Select Help > Sample Data Library and open Pizza Profiles.jmp and Pizza Responses.jmp.
Right-click the ID column in Pizza Profiles.jmp and select Link ID.
Right-click and select Link Reference > Pizza Profiles.jmp.
The selected column is linked to the ID column in Pizza Profiles.jmp.
Figure 6.40 Selected Column in Virtually Joined Data Table
In Pizza Responses.jmp, select Choice1.
Figure 6.41 Merging Referenced Data
A message confirms that the selected column was merged. Notice that the virtual join icon for Choice1 no longer appears in the Column list. The Link Reference column property was removed.
Figure 6.42 Merged Data
Help created on 3/19/2020
