Create a column called validation.
On the Column Info window, select Random from the Initialize Data list.
Select the Random Indicator radio button.
Click OK.
Select Analyze > Fit Model.
Select Stepwise in the Personality list.
Click the Run button.
7.
Select P-value Threshold from the Stopping Rule list.
8.
Click the Go button.
9.
Click the Run Model button.
10.
Save the prediction formula to a column by selecting Save Columns > Prediction Formula on the Response red triangle menu.
Figure 10.2 Fit Model Report
Select Analyze > Predictive Modeling > Partition.
Select Bootstrap Forest in the Method list.
6.
Click OK.
7.
Select the Early Stopping check box.
8.
Select the Multiple Fits over number of terms check box.
9.
Click OK.
10.
Save the prediction formula to a column by selecting Save Columns > Save Prediction Formula on the Bootstrap Forest red triangle menu.
Figure 10.3 Bootstrap Forest Model
Select Analyze > Predictive Modeling > Model Comparison.
Select the two prediction formula columns and click Y, Predictors.
Click OK.
Figure 10.4 Model Comparison Report
Figure 10.5 Prediction Profiler for All Models
Model Specification in the Fitting Linear Models book
