Select Analyze > Consumer Research > Multiple Factor Analysis.
Note: The columns in this data table are grouped into one block for each panelist. For ungrouped data, select the columns for a block, click Add Block, and repeat for each block.
6.
Click Run Model.
Figure 7.2 Initial Multiple Factor Analysis Report
7.
In the legend next to the loading plot, click Carolyn to highlight her results.
Carolyn’s results differ from the other panelists. You might want to re-run the analysis without her results. See Figure 7.6 for the results of the analysis without Carolyn.
