The data table Comptime.jmp contains data on the analysis of computer program execution time whose lognormal distribution depends on the effect Load.
Select Analyze > Reliability and Survival > Fit Parametric Survival.
Click Run.
Time quantiles are desired for when 90% of jobs are finished under a system load of 5. See Meeker and Escobar (1998, p. 438).
7.
From the red triangle menu, select Estimate Time Quantile.
8.
Type 5 as the Load.
9.
Type 0.1 as the Survival Prob.
10.
Click Go.
