For static bubble plots, you might specify one or two ID variables and no Time variable. The resulting bubble plot contains a bubble at each ID value. Note that although this bubble plot is static, you can perform splitting on bubbles.
Select Graph > Bubble Plot.
7.
Click OK.
The initial report window appears. (Figure 8.9 uses the default JMP colors.)
Figure 8.9 Initial Report Window with ID Variables
9.
Click Split.
Figure 8.10 Splitting the North America Bubble
