Select Help > Sample Data Library and open Candy Bars.jmp.
Select Analyze > Fit Model.
Select Calories and click Y.
Select Total fat g, Carbohydrate g, and Protein g, and click Add.
6.
In the Connect to SAS Server window (see Figure  .10), choose a method to connect to SAS (if you are not already connected). For this example, select Connect to SAS on this machine.
Figure  .10 Connect to SAS Server
7.
Figure  .11 SAS Results Formatted as a JMP Report
Help created on 3/19/2020
