Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Essential Graphing
Ternary Plots
Additional Examples of the Ternary Plot Platform
• Example Using Mixture Constraints
JMP.com/help
Select
Help > Sample Data Library
and open
Plasticizer.jmp
The
p1
p2
, and
p3
columns all have Mixture Column Properties defined.
From the
Graph
menu, select
Ternary Plot
Select
p1
p2
, and
p3
and click
X, Plotting
Click
OK
Figure 13.7
Mixture Constraints in a Ternary Plot
For more information about mixtures, see
Mixture Profiler
in the
Profilers
book.
Help created on 3/19/2020
