Select Analyze > Specialized Modeling > Fit Curve.
Click OK.
The Fit Curve Report appears as shown in Figure 12.2. The Plot report contains an overlaid plot of the fitted model of each formulation.
Figure 12.2 Initial Fit Curve Report
7.
To see a legend identifying each drug formulation, right-click one of the graphs and select Row Legend. Select Formulation for the column and click OK. The plot shown in Figure 12.3 appears.
Figure 12.3 Fit Curve Report with Plot Legend
The curves appear S-shaped, so a sigmoid curve would be an appropriate fit. Table 12.1 shows formulas and graphical depictions of the different types of models that the Fit Curve platform offers.
8.
Select Sigmoid Curves > Logistic Curves > Fit Logistic 4P from the Fit Curve red triangle menu.
Figure 12.4 Logistic 4P Report
The Logistic 4P report appears (Figure 12.4). There is also a separate plot for each drug formulation. The plot of the fitted curves suggests that formulation B might be different, because the test B curve starts to rise sooner than the others. Inflection point parameters cause this rise.
9.
Select Compare Parameter Estimates from the Logistic 4P red triangle menu.
Figure 12.5 Parameter Comparison Report
Notice that the Inflection Point parameter for the test B formulation is significantly lower than the average inflection point. This agrees with the plots shown in Figure 12.4. Drug formulation B has a lower toxicity ratio than the other formulations.
