Select Analyze > Reliability and Survival > Reliability Block Diagram.
Figure 11.2 New Reliability Block Diagram
Deselect Run in the Start block.
With Run selected, the platform updates the diagram’s reliability calculations after each change to the system diagram. These changes can include adding or deleting components, changing a component’s configuration, and adding or deleting a connection.
With Run deselected, the platform does not update the reliability calculations after any changes.
