Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Profilers
• Excel Profiler
JMP.com/help
Excel Profiler
Visualize Models Saved in Microsoft Excel
The JMP Add-In for Excel uses the JMP Profiler to visualize models (or formulas) stored in Excel worksheets. You can install the Excel add-in when you install JMP.
Figure 9.1
Example of a Prediction Profiler Using an Excel Model
Contents
Overview of the Excel Profiler
Example of an Excel Model
Run the JMP Profiler
Use Linear Constraints
Resolution of Profile Lines
Use the Excel Profiler from JMP
Help created on 3/19/2020
