Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Factor Analysis
• Factor Analysis Platform Options
JMP.com/help
The Factor Analysis red triangle menu contains the following options:
Eigenvalues
Shows or hides a table of the eigenvalues of the original correlation, covariance, or unscaled matrix. The table includes the percent of the total variance represented by each eigenvalue, a bar chart illustrating the percent contribution, and the cumulative percent contributed by each successive eigenvalue. The number of eigenvalues that are greater than or equal to 1.0 can be taken as a guideline of the number of factors for analysis.
Scree Plot
Shows or hides a plot of the eigenvalues versus the number of components (or factors). The plot can be used as an additional guideline to determine the number of factors that contribute to the maximum amount of variance. The point at which the plotted line levels out can be used as the number of sufficient factors for analysis.
See
Local Data Filter
Redo Menus
, and
Save Script Menus
in the
Using JMP
book for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
Help created on 3/19/2020
