Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Profilers
Mixture Profiler
The Mixture Profiler Report
• Factor Settings and Controls
JMP.com/help
Figure 6.5
T, L, R
Radio buttons to control factor assignments to the axes in the mixture profiler plot.
T
= top,
L
= left, and
R
= right.
Factor
The list of factors.
Current X
The current factor settings. Click in a box to change the value of a factor. The values for the other factors adjust proportionally to maintain the mixture sum. The slider controls can also be used to change factor settings.
Lo Limit
The lower limit on each factor. Click in a box to change the value.
Hi Limit
The upper limit on each factor. Click in a box to change the value.
Note:
When factor limits are used, the profiler shows regions that are feasible as unshaded.
Change
Opens the Factor Settings window. See
Mixture Profiler Platform Options
Help created on 3/19/2020
