Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
JMP Technical Details
• Features That Support Multithreading
JMP.com/help
Some features in JMP are coded to take advantage of multiple central processing units (CPUs) on a machine, allowing these features to run significantly faster. This process is called multithreading.
The following features support multithreading:
Boosted Trees
Bootstrap Forest
Choice
Covering Arrays
Distribution
Factor Analysis
Fit Life by X
Fit Model: Parametric Survival,
Mixed Model,
Generalized Regression, and
Response Screening
Functional Data Explorer
Gaussian (
Fast GASP and the use of Categorical variables are only in JMP Pro.)
Latent Class Analysis
Life Distribution
Multivariate
Neural (
Some features are only in JMP Pro.)
Nominal Logistic
Nonlinear and Nonlinear Curve
Normal Mixtures in Cluster Analysis
Partial Least Squares (
Partition
Predictor Screening
Principal Components
Process Screening
Profiler (Does not apply to Profilers launched from within other platforms.)
Reliability Forecast
Repairable Systems Simulation
Response Screening
Sparse Principal Components
SVD Imputation in the Missing Values Screening
Text Explorer (
SVD and Latent Class Analysis are only in JMP Pro.)
Uplift
Variable Clustering
Help created on 3/19/2020
