Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Scripting Guide
Programming Methods
• File and Directory Operations
JMP.com/help
Pick Directory()
and
Pick File()
enable the user to select a file or directory when the script is run. To get a list of files in a directory, use
Files In Directory()
Select a Directory or File
Get a List of Filenames
Connect to a Network Directory
Help created on 3/19/2020
