Produces chi-square test statistics and p-values for Wald tests of whether each parameter is zero.
Note: You can change the α level for the confidence intervals by selecting Set Alpha Level from the red triangle menu in the Fit Model launch window. The default α level is 0.05.
Help created on 3/19/2020
