Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Basic Analysis
Bivariate Analysis
• Fitting Menus
JMP.com/help
Fitting Menus
In addition to a report, each fitting option adds a fitting menu to the report window. The following table shows the fitting menus that correspond to each fitting option.
Fitting Option
Fitting Menu
Fit Mean
Fit Mean
Fit Line
Linear Fit
Fit Polynomial
Polynomial Fit Degree=X*
Fit Special
Linear Fit
Transformed Fit X*
Constrained Fits
Fit Spline
Smoothing Spline Fit, lambda=X*
Kernel Smoother
Local Smoother
Fit Each Value
Fit Each Value
Fit Orthogonal
Orthogonal Fit Ratio=X*
Fit Robust
Robust Fit
Fit Cauchy
Cauchy Fit
Density Ellipse
Bivariate Normal Ellipse P=X*
Nonpar Density
Quantile Density Colors
*X=variable character or number
Help created on 3/19/2020
