Figure 5.5 Example of the Fit Mean Option
Transforms Y and X. Transformations include: log, square root, square, reciprocal, and exponential. You can also turn off center polynomials, constrain the intercept and the slope, and fit polynomial models. See Fit Special.
Note: You can remove a fit using the Remove Fit option. For details, see Fitting Menu Options.
Help created on 3/19/2020
