Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Full Factorial Designs
• Full Factorial Design Window
JMP.com/help
The Full Factorial design window updates as you work through the design steps. For more information, see
The DOE Workflow: Describe, Specify, Design
. The outlines, separated by buttons that update the outlines, follow the flow in
Figure 12.7
Figure 12.7
Full Factorial Design Flow
Help created on 3/19/2020
