Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
Enter and Edit Data
Organize Data
• Hide Columns
JMP.com/help
Hide Columns
When your data table contains columns that you do not want to see in the data grid, you can hide those columns. Note the following:
Hidden columns appear in launch windows and are available for analyses.
A mask icon (
) appears to the right of the column name in the Columns panel.
To hide columns
Select one or more columns that you want to hide.
Do one of the following:
Right-click on the highlighted column name in the Columns panel and select
Hide/Unhide.
From the
Cols
menu, select
Hide/Unhide
To unhide columns
Select the columns in the Columns panel.
Hide/Unhide.
From the
Cols
menu, select
Hide/Unhide
Help created on 3/19/2020
