Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Basic Analysis
Distributions
Options for Categorical Variables
• Histogram Options for Categorical Variables
JMP.com/help
Histogram
Shows or hides the histogram. See
Histograms
Vertical
Changes the orientation of the histogram from a vertical to a horizontal orientation.
Std Error Bars
Draws the standard error bar on each level of the histogram.
Separate Bars
Separates the histogram bars.
Histogram Color
Changes the color of the histogram bars.
Count Axis
Adds an axis that shows the frequency of column values represented by the histogram bars.
Prob Axis
Adds an axis that shows the proportion of column values represented by histogram bars.
Density Axis
Adds an axis that shows the length of the bars in the histogram.
The count and probability axes are based on the following calculations:
prob = (bar width)*density
count = (bar width)*density*(total count)
Show Percents
Labels the percent of column values represented by each histogram bar.
Note:
To specify the number of decimal places, right-click the histogram and select
Customize > Histogram
Show Counts
Labels the frequency of column values represented by each histogram bar.
Help created on 3/19/2020
