Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Basic Analysis
Distributions
Options for Continuous Variables
• Histogram Options for Continuous Variables
JMP.com/help
Histogram
Shows or hides the histogram. See
Histograms
Shadowgram
Replaces the histogram with a shadowgram. To understand a shadowgram, consider that if the bin width of a histogram is changed, the appearance of the histogram changes. A shadowgram overlays histograms with different bin widths. Dominant features of a distribution are less transparent on the shadowgram.
Note that the following options are not available for shadowgrams:
Std Error Bars
Show Counts
Show Percents
Vertical
Changes the orientation of the histogram from a vertical to a horizontal orientation.
Std Error Bars
Draws the standard error bar on each level of the histogram using the standard error. The standard error bar adjusts automatically when you adjust the number of bars with the hand tool. See
Resize Histogram Bars for Continuous Variables
and
Standard Error Bars
Set Bin Width
Changes the bin width of the histogram bars. See
Histogram Color
Changes the color of the histogram bars.
Count Axis
Adds an axis that shows the frequency of column values represented by the histogram bars.
Note:
If you resize the histogram bars, the count axis also resizes.
Prob Axis
Adds an axis that shows the proportion of column values represented by histogram bars.
Note:
If you resize the histogram bars, the probability axis also resizes.
Density Axis
The density is the length of the bars in the histogram. Both the count and probability are based on the following calculations:
prob = (bar width)*density
count = (bar width)*density*(total count)
When looking at density curves that are added by the Fit Distribution option, the density axis shows the point estimates of the curves.
Note:
If you resize the histogram bars, the density axis also resizes.
Show Percents
Labels the proportion of column values represented by each histogram bar.
Show Counts
Labels the frequency of column values represented by each histogram bar.
Help created on 3/19/2020
