In the Effect Tests report, each continuous main effect with missing values has Nparm = 2. In the Parameter Estimates report, the parameter for a continuous main effect with missing values is labeled <colname> Or Mean if Missing and the indicator parameter is labeled <colname> Is Missing. Prediction formulas that you save to the data table are given in terms of expressions corresponding to these model parameters.
In the Parameter Estimates report, the parameter for a nominal effect is labeled <colname>[ ]. For an ordinal effect, the parameter is labeled <colname>[-x], where x denotes the level with highest value ordering.
Help created on 3/19/2020
