The IRT model assumes that the underlying trait is unidimensional. That is, there is a single underlying latent construct. If there are several traits that have complex interactions with each other being measured, then a unidimensional model is not appropriate. The IRT model is appropriate for continuous latent variables. For a categorical latent variable, you should consider a latent class model. See the Latent Class Analysis topic. IRT models are assumed to be item-invariant. Item-invariance means that P(θ) is interpreted as the probability of a correct response for a set of individuals with ability level θ. If a large group of individuals with equal ability levels answered the item, P(θ) predicts the proportion who would answer the item correctly. This implies that IRT models would have the same parameters regardless of the group of subjects tested. In addition, the IRT model assumes local independence, which means that once the latent construct has been accounted for, the items are independent of one another.
Help created on 3/19/2020
