Click Toggle Layout to display the Recent Files and Windows lists horizontally instead of vertically.
Open the JMP Home window on Macintosh by selecting Window > JMP Home (Figure 2.15). To view the window each time you open JMP, select JMP > Preferences > General > Home Window.
Figure 2.15 Example of the JMP Home Window (Macintosh)
To be able to quickly view the JMP Home window from any JMP window, right-click the window, select Customize Toolbar, and drag the JMP Home icon to the toolbar.
Tip: To prevent files that were opened by scripts from appearing in the Recent Files window, select File > Preferences > General and de-select Add files opened by scripts to the Recent Files list.
To close a window, click the x button that appears when you place your cursor over the window in the Windows list.
If the window that you are closing is a parent to one or more children, you are prompted to Hide Data Table, Cancel, or Close All windows. Select Close All to close the parent and all its children windows.
